The replacement of your Dell Latitude E6420 laptop’s CPU may be needed in certain circumstances. This may include simply upgrading to a newer model when your current model has become obsolete or a failure of the current CPU. A common sign that your CPU may need to be replaced is the freezing of your laptop. Freezing of the laptop and the unresponsiveness may indicate that your CPU will need to be replaced. Another issue may be that the laptop will not boot up and the screen may even be blank even though your device is being powered. Convenience may also be a reason to upgrade your CPU. An upgrade will increase processing power and improving performance, making applications and programs load faster. The newer CPU may be more compatible with newer software and hardware. It may also be more energy efficient extending battery life for your device. For this replacement, no special skills are needed.
Remove the eight screws holding down the rear panel using a Phillips #0 Screwdriver. Carefully remove base cover by hand.
Remove the battery by pushing the tabs outward, then removing the battery from the device.
Remove the four screws securing the heatsink using the Phillips #0 screwdriver.
Remove the heatsink and fan assembly.
Use the flat end of a spudger to rotate the lock 180 degrees counterclockwise to unlock the CPU.
Lift the CPU out of the motherboard assembly.
