Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly)
  1. Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Bottom cover removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Bottom cover removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the 8 screws on the bottom cover. The screws will remain in the casing, they do not come out all the way.
    • Insert the pick or spudger between the upper and lower casing to release the plastic clips.
    • Attention needed: The clips are easily broken.
  2. Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Disconnect the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To disconnect the battery, pull gently upwards on the tab connector.
  3. Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Remove the LCD Bezel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a pick or spudger, gently insert between the LCD back-cover and bezel to release the clips.
    • The bezel is also glued to the LCD panel.
    • Remove slowly to avoid tearing or damaging any components underneath.
  4. Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Removing the LCD panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 Philips screws securing the panel.
  5. Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Remove the LCD Connector: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Remove the LCD Connector: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Remove the LCD Connector: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the LCD paneland lay it flat on the keyboard.
    • You will be able to see the connector on the back of the LCD panel secured with some adhesive tape and a metal connector.
    • Udsing the tweezers, slowly lift the tape away to reveal the blue sticky protector. Removing the blue pad to see the metal connector underneath.
    • Using a spudger, lift the front of the connector up (highlighted by the white arrow).
    • Pull the cable back to release the cable from the connector.
    • To reassemble, follow the steps in reverse.
Harvey
crwdns2935283:002/15/16crwdne2935283:0
6,051 crwdns2915208:0crwdne2915208:0
crwdns2947412:05crwdne2947412:0
Hello, will this model with touch screen work with non touch replacement LCD?
cellularcircuit - crwdns2934203:0crwdne2934203:0
Damaged touch lcd and was not using touch , want to save some $ by installing not touch lcd..
cellularcircuit -
Thanks - seems that little piece of blue sticky protector was my whole problem, months of a flickering screen, that was temporarily fixed upon pressing on the bottom of the bezel. Upon opening up the screen, it was crooked. So I straightened it, put things back together, and the flickering seems to be gone. Cross my fingers!
Peter Lyons - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 9,011
