Dell Latitude D830 Keyboard Replacement
  1. Dell Latitude D830 Keyboard Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the laptop so that the back is facing you.
    • With a phillip's head screwdriver, remove the two screws on the back corners of the laptop.
  2. Dell Latitude D830 Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over, with the opening still facing up.
    • With a phillip's head screwdriver remove the two screws in the upper two corners.
  3. Dell Latitude D830 Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the laptop up. Displaying the keyboard and screen.
    • Take a spudger and insert it under the left edge of the panel between the keyboard and screen.
    • Use the spudger to pry under the panel.
  4. Dell Latitude D830 Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the spudger under the middle of the panel and use it to pry the panel off.
  5. Dell Latitude D830 Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the spudger under the right side of the panel and use it to pry the panel off.
    • For additional help the spudger can be placed around the edge of the panel and used to pry it off.
  6. Dell Latitude D830 Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After you have the panel popped out, then you must pull the screen up as shows in the picture.
  7. Dell Latitude D830 Keyboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The screen will only be connected by the wiring.
    • Take the screen and gently place it on the table as shown in the picture.
    • Now you must remove the three screws highlighted in the picture.
  8. Dell Latitude D830 Keyboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the three screws, slide the keyboard out so the mainframe of it is loose.
    • The a component still attached at the bottom.
  9. Dell Latitude D830 Keyboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The highlighted item should be the only component holding the keyboard on.
  10. Dell Latitude D830 Keyboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Where the rectangle is, there is a silver lever that you must push back.
    • Then where the circle is on the photo, you must take the spudger and push in.
    • This will then pop the white clip off and the keyboard will be free.
  11. Dell Latitude D830 Keyboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The keyboard is now completely detached, and is ready to be replaced.
Talley
crwdns2935283:002/05/19crwdne2935283:0
268 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S3-G13, Eggleston Spring 2019 crwdns2935289:0The Citadel Military College of South Carolina, Team S3-G13, Eggleston Spring 2019crwdne2935289:0
CMCSC-EGGLESTON-S19S3G13
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 1,000
