Dell Latitude D820 Memory Chip (RAM) Replacement
    • Shut down your computer. Disconnect all power sources before opening the computer cover or panels.
    • Remove the battery, hinge cover, and keyboard from the computer.
    • Ground yourself by touching one of the metal connectors on the back of the computer.
    • If you leave the area, ground yourself again when you return to the computer.
  1. Dell Latitude D820 Memory Chip (RAM) Replacement, DIMM A Connector RAM - Step 3: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the module from the connector.
    • Insert memory modules at a 45-degree angle to avoid damaging the connector. If the memory module is not installed properly, the computer may not boot properly. No error message indicates this failure.
    • Ground yourself and install the new memory module by aligning the notch in the module edge connector with the tab in the connector slot.
    • Slide the module firmly into the slot, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
    • If you're willing to replace or install the memory module/chip in the DIMM B connector, only insert or replace the keyboard and hinge cover.
    • Insert or replace the keyboard, hinge cover, and battery on the computer respectively.
    • After turning on your computer, it should detect the amount of RAM installed, if RAM is installed correctly.
  2. Dell Latitude D820 Memory Chip (RAM) Replacement, DIMM B Connector RAM - Step 1: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you haven't done so, shut down your computer. Disconnect all power sources before opening the computer cover or panels. Remove the battery afterward.
    • Turn the computer upside-down, loosen the captive screw on the memory module cover (see image), and remove the cover.
  3. Dell Latitude D820 Memory Chip (RAM) Replacement, DIMM B Connector RAM - Step 2: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you are replacing a memory module, remove the existing module by using your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • For optimal performance, identical memory modules should be used in each connector.
    • Replace the memory module cover.
    • If the cover is difficult to close, remove the module and reinstall it. Forcing the cover to close may damage your computer.
    • Insert the battery into the battery bay, or connect the AC adapter (charger) to your computer and an electrical outlet.
    • Turn on the computer.
Hezekiah Brown
crwdns2935283:002/11/21crwdne2935283:0
6,250 crwdns2915208:0crwdne2915208:0
crwdns2935297:049crwdne2935297:0
RampUP America, Inc. crwdns2935289:0RampUP America, Inc.crwdne2935289:0
Community
crwdns2931471:043crwdne2931471:0
crwdns2935297:01,991crwdne2935297:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 294
