Dell Latitude D820 Keyboard Replacement
  1. Dell Latitude D820 Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the charger from the laptop.
    • Turn the laptop over and locate the battery slide lock. Slide the switch and gently lift up the battery.
    • If you are replacing other components, leave the battery out.
    • If you are only replacing the battery, reverse the steps to install a new battery.
  2. Dell Latitude D820 Keyboard Replacement, Keyboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude D820 Keyboard Replacement, Keyboard: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude D820 Keyboard Replacement, Keyboard: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open laptop lid and extend screen until it is parallel with the keyboard.
    • Locate the notch in the upper right corner of the keyboard (just above the 'page up' button).
    • Insert the plastic spudger and very gently lift the faceplate. It will make a soft snapping sound.
    • Set aside.
  3. Dell Latitude D820 Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the three philips head screws above the keyboard. One is above the 'Pause/Break' key; one above the F7 key and one above the 'Esc' key. Remove all three.
  4. Dell Latitude D820 Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift top of keyboard and lay forward on palm rest.
    • Locate blue pull tab and gently disconnect ribbon cable from motherboard.
crwdns2935229:05crwdne2935229:0
Michael Coleman
crwdns2935283:009/09/14crwdne2935283:0
162 crwdns2915208:0crwdne2915208:0
Pasco Hernando, Team 1-2, Prince Fall 2014 crwdns2935289:0Pasco Hernando, Team 1-2, Prince Fall 2014crwdne2935289:0
PHSC-PRINCE-F14S1G2
crwdns2931471:010crwdne2931471:0
I am the author of a high-altitude cookbook. I self-publish. My "A" key decided to stop working on my dell XP, and then the internet would not connect. When I finally purchased a new computer Windows 8, I discovered I could not format it for my hp business injet 2300. This printer is a duplexer, and key to my cookbook business. The other problem was Quark Express 6.1 would not work on it. Two thousand plus seemed a little high for a new Quark. After fiddling around with the internal keyboard and using the "copy and replace function" I decided on a new keyboard. Found a new one on ebay cheap. The instructions here were a blessing. Thank you, thank you, thank you! I now have my XP back working like new. The Windows 8 can be for the internet,
DAWN KLEIN - crwdns2934203:0crwdne2934203:0
Thank you very much. I am glad it helped and your back up and running. Just a side note: Be careful using Windows XP on the Internet these days, since it no longer receives security updates from Microsoft. Thanks again!
Henry -
You gave great directions. I never reassembled something I took apart. Worked like a charm Thanks so much!!!
Cheryl Baynard - crwdns2934203:0crwdne2934203:0
Beautifully clear - perfect! Thank you.
David Harmsworth - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 2,132
