Dell Latitude D630 Hard Drive Replacement
  1. Dell Latitude D630 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Dell Latitude D630 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. Dell Latitude D630 Hard Drive Replacement, Hard Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude D630 Hard Drive Replacement, Hard Drive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude D630 Hard Drive Replacement, Hard Drive: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Position the closed laptop upside down.
    • Unscrew the screw closest to the hard drive opening and the one diagonally to the right. This will loosen the hard drive.
    • Do not unscrew this screw!
  4. Dell Latitude D630 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place thumb on the hard drive cover and get a firm grip.
    • Pull the hard drive out slowly to avoid any further damage to the laptop.
  5. Dell Latitude D630 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude D630 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the screw on the right side to remove cover.
    • Slide cover off.
crwdns2935229:017crwdne2935229:0
Savi Chavan
crwdns2935283:003/12/14crwdne2935283:0
987 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-4, Cichon Spring 2014 crwdns2935289:0UMass Dartmouth, Team 1-4, Cichon Spring 2014crwdne2935289:0
UMASSD-CICHON-S14S1G4
I appreciate the guide my good sir. Very helpful.
Matt Erti - crwdns2934203:0crwdne2934203:0
Is the hard drive replaceable to 2.5-inch SSD? for example Kingston a400.
Aduh - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 16,050
