Guide to separating the display from the body of the laptop.
Open the laptop cover all of the way.
Locate the notch under the cover at the top of the keyboard
Using the spudger as a lever, lift the plastic covering
Carefully remove the rest of the covering from right to left
Unscrew the top portion of the keyboard using a #00 screwdriver
Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
Once keyboard is out of the case, lay it face-down on the track pad
Using a small spudger, pull back on the black bar to release the blue lever
Pull up on the metal bar connected to the socket to detach the ribbon cable
Detach cables that connect the display to the body of the laptop
Disconnect the black cable attached to the motherboard
Close the laptop lid
Turn the laptop over onto its backside
Unscrew the two screws shown in the picture using a #00 screwdriver
Face the laptop's back ports towards you
Unscrew the two screws labeled in the picture using a #00 screwdriver
Turn the laptop over again so it's right-side up
Open the display, and pull the display up and out of the laptop's body
Remove the circular rubber pads as outlined in the picture using a spudger
Unscrew the screws that were under the rubber circles using the #00 screwdriver
Carefully use a spudger to work around the edge of the screen to lift off the plastic cover
Remove the screws outlined in the picture
Carefully lift the LCD screen out of its casing
crwdns2935229:019crwdne2935229:0
Check out this replacement screen at a great price on bcdelectrostore.com
Please help me
manaqib arif - crwdns2934203:0crwdne2934203:0
Mera display ka masla hai
