Dell Latitude D620 Display Replacement
  1. Dell Latitude D620 Display Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
  2. Dell Latitude D620 Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude D620 Display Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude D620 Display Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
  3. Dell Latitude D620 Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the top portion of the keyboard using a #00 screwdriver
  4. Dell Latitude D620 Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
  5. Dell Latitude D620 Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude D620 Display Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once keyboard is out of the case, lay it face-down on the track pad
  6. Dell Latitude D620 Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude D620 Display Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a small spudger, pull back on the black bar to release the blue lever
  7. Dell Latitude D620 Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
  8. Dell Latitude D620 Display Replacement, Display: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach cables that connect the display to the body of the laptop
  9. Dell Latitude D620 Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the black cable attached to the motherboard
  10. Dell Latitude D620 Display Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude D620 Display Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Close the laptop lid
    • Turn the laptop over onto its backside
    • Unscrew the two screws shown in the picture using a #00 screwdriver
  11. Dell Latitude D620 Display Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude D620 Display Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Face the laptop's back ports towards you
    • Unscrew the two screws labeled in the picture using a #00 screwdriver
  12. Dell Latitude D620 Display Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop over again so it's right-side up
    • Open the display, and pull the display up and out of the laptop's body
  13. Dell Latitude D620 Display Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the circular rubber pads as outlined in the picture using a spudger
  14. Dell Latitude D620 Display Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the screws that were under the rubber circles using the #00 screwdriver
  15. Dell Latitude D620 Display Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully use a spudger to work around the edge of the screen to lift off the plastic cover
    • Be very careful while doing this as the plastic snaps easily
  16. Dell Latitude D620 Display Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws outlined in the picture
  17. Dell Latitude D620 Display Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the LCD screen out of its casing
crwdns2935229:019crwdne2935229:0
Miguel Wong
crwdns2935283:004/15/10crwdne2935283:0
562 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-35, Regan Spring 2010 crwdns2935289:0Cal Poly, Team 24-35, Regan Spring 2010crwdne2935289:0
CPSU-REGAN-S10S24G35
Check out this replacement screen at a great price on bcdelectrostore.com
http://www.bcdelectrostore.com/magento/l...
bob harris - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 33,415
