crwdns2944444:0crwdne2944444:0
crwdns2944446:0crwdne2944446:0
crwdns2959928:0crwdne2959928:0 ↓This guide will show how to add RAM or replace existing RAM on the Latitude D600
Find the panel underneath the microsoft product key sticker, the panel is labeled with an M
Unscrew the single screw above the M
Pull off the panel to reveal the RAM
RAM is held in by two tabs, pull each tab to the side and the RAM will pop up
Once the RAM is popped up, slowly pull it out of the slot
To add or replace RAM, place the memory into the slot at an angle
Make sure you line it up correctly
If it is in correctly it should stay up at an angle by itself
Then push down in the middle until it clicks into place
The RAM should be secured by the tabs where the two semi circles are on the RAM
If it is not secure, just gently pull it out and try again, use the images to help you out
Almost perfect: easy; clear;
Herman - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
