Dell Latitude D530 Hard Drive Replacement
  1. Dell Latitude D530 Hard Drive Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The hard drive will be located in the side of the laptop.
    • Unscrew the two bottom 6mm screws using Phillips #1.
  2. Dell Latitude D530 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove cover to hard drive bay.
  3. Dell Latitude D530 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude D530 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull hard drive out.
    I have a problem with the same laptop where the drive is not recognised in the bios. Occasionally it will be recognised, but I tried a number of working SSD drives and SATA drives Sam with same problem. I suspect the actual physical connection or sate cable in the unit is the problem. Do you have a breakdown on how to access the cable to reseat or replace the internal cable?
    Jonathan Joffe - crwdns2934203:0crwdne2934203:0
Kyle Cabral
crwdns2935283:003/19/18crwdne2935283:0
604 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S2-G6, Bernier Spring 2018 crwdns2935289:0UMass Dartmouth, Team S2-G6, Bernier Spring 2018crwdne2935289:0
UMASSD-BERNIER-S18S2G6
What is a screw is stuck and won’t come out?
Феропонт Досифеев - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,779
