Dell Latitude 9510 Battery Replacement
  1. Dell Latitude 9510 Battery Replacement, Base Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device so that the base plate is facing you.
    • Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
  2. Dell Latitude 9510 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge a spudger between the base plate and the chassis, then gently pry around the entire perimeter to release the base plate.
    • Remove the base plate.
  3. Dell Latitude 9510 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the eight screws securing the battery.
    Hey, great explanation. I have installed a 11v 88Wh battery and the right hand side (as per your pictures) does not fit properly into the laptop chassis. Any suggestions?
    Christian Oddono - crwdns2934203:0crwdne2934203:0
  4. Dell Latitude 9510 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place a spudger behind a plastic tab on either side of the plug, then "walk" the connector out of its socket by gently pushing the plug toward the cables, alternating sides, until the connector releases.
    • Lift the battery up and out.
David Cauley
crwdns2935283:002/10/22crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-5, Virtue Spring 2022 crwdns2935289:0Western Carolina University, Team 1-5, Virtue Spring 2022crwdne2935289:0
WCU-VIRTUE-S22S1G5
I have the Version with the 52 Wh battery.
Is it possible to upgrade my laptop to the 88 Wh battery?
Would appreciate any Insights on this!
Johann Mangelsen - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,187
