Dell Latitude 9410 2-in-1 Motherboard Replacement
  1. Dell Latitude 9410 2-in-1 Motherboard Replacement, Base Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 9410 2-in-1 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 9410 2-in-1 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 9410 2-in-1 Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 Motherboard Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 9410 2-in-1 Motherboard Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Philips #00 screwdriver to remove the five 3mm screws that secure the battery.
  5. Dell Latitude 9410 2-in-1 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 9410 2-in-1 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 9410 2-in-1 Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Philips #00 screwdriver to remove one 4.5 mm screw.
  6. Dell Latitude 9410 2-in-1 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 9410 2-in-1 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the battery cable near the plug and pull it straight out, in the direction of the cable.
  7. Dell Latitude 9410 2-in-1 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 9410 2-in-1 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to gently move the speaker ribbon cable away from the bottom of the battery.
    • The ribbon cable is thin and fragile; handle it carefully.
    • The ribbon cable only needs to be moved so that the battery can be removed; do not completely remove the ribbon cable.
  8. Dell Latitude 9410 2-in-1 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 9410 2-in-1 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery out with two hands.
  9. Dell Latitude 9410 2-in-1 Motherboard Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Philips #00 screwdriver to remove the two 2 mm screws that secure the fan.
  10. Dell Latitude 9410 2-in-1 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two ribbon cables connected to the motherboard by lifting the black ZIF tab and pulling the ribbon cables free.
  11. Dell Latitude 9410 2-in-1 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two Wi-Fi card cables by prying them up and away from the press-fit connector.
  12. Dell Latitude 9410 2-in-1 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the small black wire from the mother board by pulling in the direction of the cable.
    • Disconnect the black and red wire from the motherboard, also by pulling the direction of the cable.
  13. Dell Latitude 9410 2-in-1 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Philips #00 screwdriver to remove the eight 3 mm screws that secure the motherboard.
Brenden William Johnson
crwdns2935283:010/04/22crwdne2935283:0
334 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team 3-16, Eggleston Fall 2022 crwdns2935289:0The Citadel Military College of South Carolina, Team 3-16, Eggleston Fall 2022crwdne2935289:0
CMCSC-EGGLESTON-F22S3G16
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 611
