Dell Latitude 7420 SSD Replacement
  1. Dell Latitude 7420 SSD Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 7420 SSD Replacement, Back Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 7420 SSD Replacement, Back Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the eight, 7 mm screws from the back case using a Phillips #0 screwdriver.
    • Use an opening pick or opening tool and work your way around the periphery of the base cover to separate it from the chassis.
  2. Dell Latitude 7420 SSD Replacement, SSD: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 7420 SSD Replacement, SSD: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 7420 SSD Replacement, SSD: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the two 2.0 mm screws holding down the SSD cover.
    • Remove the SSD cover.
    • Notice that the left screw is also pinning the SSD card in place.
  3. Dell Latitude 7420 SSD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the SSD card by its left edge to slide it out of the socket.
Nick B.
crwdns2935283:008/25/22crwdne2935283:0
716 crwdns2915208:0crwdne2915208:0
Gateway, Team 1-2, Pee Spring 2023 crwdns2935289:0Gateway, Team 1-2, Pee Spring 2023crwdne2935289:0
GCC-PEE-S23S1G2
Thanks this helped out alot
Anna Cruz - crwdns2934203:0crwdne2934203:0
Can I put the SSD cover back on after installing the SSD? It appears to have some paste on it, assuming it's for cooling?
Emily - crwdns2934203:0crwdne2934203:0
This is the ONLY internal storage on this laptop, right? So we need to make a Windows backup before starting?
Laura Doan - crwdns2934203:0crwdne2934203:0
Yes it is the ONLY storage in the device. You definitely need a Windows backup. Alternatively you can reinstall Windows completely new.
Daniel Kramp -
crwdns2936753:07crwdne2936753:0 61
crwdns2936753:030crwdne2936753:0 232
crwdns2942667:0crwdne2942667:0 5,282
