This tutorial will guide you through replacing the SSD card of a Dell Latitude 7420.
Before starting, please ensure the device is turned off and disconnected from any adaptors or charging cables.
Likewise, use an anti-static band or mat when opening computers or handling components.
Remove the eight, 7 mm screws from the back case using a Phillips #0 screwdriver.
Use an opening pick or opening tool and work your way around the periphery of the base cover to separate it from the chassis.
Use a Phillips #00 screwdriver to remove the two 2.0 mm screws holding down the SSD cover.
Remove the SSD cover.
Pull the SSD card by its left edge to slide it out of the socket.
Thanks this helped out alot
Can I put the SSD cover back on after installing the SSD? It appears to have some paste on it, assuming it's for cooling?
This is the ONLY internal storage on this laptop, right? So we need to make a Windows backup before starting?
Yes it is the ONLY storage in the device. You definitely need a Windows backup. Alternatively you can reinstall Windows completely new.
