Dell Latitude 7420 Display Replacement
  1. Dell Latitude 7420 Display Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 7420 Display Replacement, Back Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 7420 Display Replacement, Back Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the eight, 7 mm screws from the back case using a Phillips #0 screwdriver.
    • Use an opening pick or opening tool and work your way around the periphery of the base cover to separate it from the chassis.
  2. Dell Latitude 7420 Display Replacement, Display: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 7420 Display Replacement, Display: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 7420 Display Replacement, Display: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the three, 2 mm screws fastening the cable covers.
    • Remove both cable covers.
  3. Dell Latitude 7420 Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 7420 Display Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to detach the coaxial cables from the Wi-Fi card.
    • Disconnect the remaining cables connecting the display assembly to the board.
  4. Dell Latitude 7420 Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 7420 Display Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 7420 Display Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the four 4 mm screws securing the display hinges.
    • There are two screws to remove from each hinge.
    • Lift the base to pull the display assembly free.
  5. Dell Latitude 7420 Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the display assembly from the base of the laptop.
nuredinroba
crwdns2935283:002/02/23crwdne2935283:0
209 crwdns2915208:0crwdne2915208:0
Gateway, Team 1-2, Pee Spring 2023 crwdns2935289:0Gateway, Team 1-2, Pee Spring 2023crwdne2935289:0
GCC-PEE-S23S1G2
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 2,033
