Dell Latitude 7410 SIM Card Tray Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Dell Latitude 7410 SIM Card Tray Removal, Unfasten the back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to loosen the eight captive screws securing the back cover.
  2. Dell Latitude 7410 SIM Card Tray Removal, Insert an opening pick: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 7410 SIM Card Tray Removal, Insert an opening pick: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick between the right edge of the back cover and the frame, just below the middle right screw.
  3. Dell Latitude 7410 SIM Card Tray Removal, Unclip the right edge: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 7410 SIM Card Tray Removal, Unclip the right edge: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide your pick along the right edge to release the clips securing the back cover.
  4. Dell Latitude 7410 SIM Card Tray Removal, Unclip the left edge: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 7410 SIM Card Tray Removal, Unclip the left edge: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 7410 SIM Card Tray Removal, Unclip the left edge: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert your pick between the left edge of the back cover and the frame, next to the speaker cutout.
    • Slide your pick along the left edge to release the clips.
  5. Dell Latitude 7410 SIM Card Tray Removal, Unclip the back edge: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 7410 SIM Card Tray Removal, Unclip the back edge: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 7410 SIM Card Tray Removal, Unclip the back edge: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert your pick between the back cover and the right display-hinge to release the first clip along the back edge.
    • Slide your pick toward the left hinge until the second clip releases.
  6. Dell Latitude 7410 SIM Card Tray Removal, Unclip the front edge: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 7410 SIM Card Tray Removal, Unclip the front edge: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert your pick between the front edge of the back cover and the frame, just to the right of the bottom left screw.
    • Slide your pick toward the right edge until the front edge releases from the frame.
  7. Dell Latitude 7410 SIM Card Tray Removal, Remove the back cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 7410 SIM Card Tray Removal, Remove the back cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back cover.
  8. Dell Latitude 7410 SIM Card Tray Removal, Disconnect the battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 7410 SIM Card Tray Removal, Disconnect the battery: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the black pull tab on the head of the battery connector and pull straight up to disconnect it.
  9. Dell Latitude 7410 SIM Card Tray Removal, Remove the cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 7410 SIM Card Tray Removal, Remove the cover: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 7410 SIM Card Tray Removal, Remove the cover: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If your laptop doesn't come with a WWAN card, skip the next two steps.
    • Use the flat end of a spudger to pry up the WWAN card cover from its clips on the I/O board.
    • Remove the cover.
  10. Dell Latitude 7410 SIM Card Tray Removal, Remove the WWAN cable bracket: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 7410 SIM Card Tray Removal, Remove the WWAN cable bracket: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 7410 SIM Card Tray Removal, Remove the WWAN cable bracket: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your Phillips screwdriver to remove the 3 mm screw securing the WWAN cable bracket.
    • Remove the cable bracket.
  11. Dell Latitude 7410 SIM Card Tray Removal, Remove the antenna cable bracket: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 7410 SIM Card Tray Removal, Remove the antenna cable bracket: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 7410 SIM Card Tray Removal, Remove the antenna cable bracket: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your Phillips screwdriver to remove the 3 mm screw securing the antenna cable bracket.
    • Remove the antenna cable bracket.
  12. Dell Latitude 7410 SIM Card Tray Removal, Disconnect the antenna cables: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 7410 SIM Card Tray Removal, Disconnect the antenna cables: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 7410 SIM Card Tray Removal, Disconnect the antenna cables: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your spudger to disconnect the antenna press connectors labeled 1 and 2 by prying the heads of their connectors straight up.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  13. Dell Latitude 7410 SIM Card Tray Removal, Move the antenna cables: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 7410 SIM Card Tray Removal, Move the antenna cables: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 7410 SIM Card Tray Removal, Move the antenna cables: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This step shows a laptop that didn't come with a WWAN card. If yours has one, disconnect and remove it now.
    • Lift the antenna cables out from their cable routing on the I/O board and move them away from the board.
  14. Dell Latitude 7410 SIM Card Tray Removal, Remove the SIM card tray: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 7410 SIM Card Tray Removal, Remove the SIM card tray: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 7410 SIM Card Tray Removal, Remove the SIM card tray: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a SIM card eject tool, bit, or straightened paperclip into the SIM eject hole.
    • Use your fingers to remove the SIM card tray.
Clay Eickemeyer
crwdns2935283:009/19/22crwdne2935283:0
86 151 crwdns2915208:0crwdne2915208:0
crwdns2935297:0455crwdne2935297:0
Guide Team crwdns2935289:0Guide Teamcrwdne2935289:0
Staff
crwdns2931471:09crwdne2931471:0
crwdns2935297:013 343crwdne2935297:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 12
