If you need to repair or replace the fan component in the Dell Latitude 7390, this guide shows you step-by-step how to access it.
Prior to starting this repair, be sure to turn off your laptop and unplug from the power adapter.
Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
Flip your laptop over so that the bottom is facing up.
Using your Phillips #1 screwdriver, remove the eight 6 mm screws around the border of the bottom panel.
Using an opening tool or picks, work your way around the periphery and pry the back case off.
Finally, lift the back panel off to uncover the inside of your Dell Latitude 7390.
Use the Phillips #1 screwdriver to remove the five 6 mm screws holding the battery in place along the edges of the battery.
Pull the black tab on the top of the connector to unplug the battery from the motherboard.
Carefully lift the battery out of the laptop.
Remove the five black screws holding the fan and heatsink in place using the Phillips #0 screwdriver.
Use tweezers or your fingers to disconnect the fan connector.
