Dell Latitude 7390 (2-in-1) Wi-Fi Card Replacement
  1. Dell Latitude 7390 (2-in-1) Wi-Fi Card Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
  2. Dell Latitude 7390 (2-in-1) Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 7390 (2-in-1) Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 7390 (2-in-1) Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip your laptop over so that the bottom is facing up.
  3. Dell Latitude 7390 (2-in-1) Wi-Fi Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your Phillips #1 screwdriver, remove the eight 6 mm screws around the border of the bottom panel.
  4. Dell Latitude 7390 (2-in-1) Wi-Fi Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 7390 (2-in-1) Wi-Fi Card Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using an opening tool or picks, work your way around the periphery and pry the back case off.
  5. Dell Latitude 7390 (2-in-1) Wi-Fi Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Finally, lift the back panel off to uncover the inside of your Dell Latitude 7390.
  6. Dell Latitude 7390 (2-in-1) Wi-Fi Card Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the laptop is turned OFF and unplugged from the power adapter before taking the battery out.
    • Use the Phillips #1 screwdriver to remove the five 6 mm screws holding the battery in place along the edges of the battery.
  7. Dell Latitude 7390 (2-in-1) Wi-Fi Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 7390 (2-in-1) Wi-Fi Card Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 7390 (2-in-1) Wi-Fi Card Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful not to break the connector by pulling too hard on the black tab.
    • Pull the black tab on the top of the connector to unplug the battery from the motherboard.
  8. Dell Latitude 7390 (2-in-1) Wi-Fi Card Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the battery out of the laptop.
  9. Dell Latitude 7390 (2-in-1) Wi-Fi Card Replacement, Wi-Fi Card: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 7390 (2-in-1) Wi-Fi Card Replacement, Wi-Fi Card: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the 3 mm screw securing the Wi-Fi card.
  10. Dell Latitude 7390 (2-in-1) Wi-Fi Card Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the coaxial connectors from the Wi-Fi card with tweezers.
    • Before removing the wires, it is important to note the location of the corresponding connectors. When it comes to reconnecting the wires they will need to be placed in the correct port in order to function correctly.
  11. Dell Latitude 7390 (2-in-1) Wi-Fi Card Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the wires have been disconnected, pull the chip out of the connector and place the part aside.
Glennjay Elayda
crwdns2935283:002/22/22crwdne2935283:0
288 crwdns2915208:0crwdne2915208:0
Clemson, Team 1-4, Hunter Spring 2022 crwdns2935289:0Clemson, Team 1-4, Hunter Spring 2022crwdne2935289:0
CLEM-HUNTER-S22S1G4
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 1,717
