Dell Latitude 7390 (2-in-1) Fan Replacement
  1. Dell Latitude 7390 (2-in-1) Fan Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
  2. Dell Latitude 7390 (2-in-1) Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 7390 (2-in-1) Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 7390 (2-in-1) Fan Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip your laptop over so that the bottom is facing up.
  3. Dell Latitude 7390 (2-in-1) Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your Phillips #1 screwdriver, remove the eight 6 mm screws around the border of the bottom panel.
  4. Dell Latitude 7390 (2-in-1) Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 7390 (2-in-1) Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using an opening tool or picks, work your way around the periphery and pry the back case off.
  5. Dell Latitude 7390 (2-in-1) Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Finally, lift the back panel off to uncover the inside of your Dell Latitude 7390.
  6. Dell Latitude 7390 (2-in-1) Fan Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the laptop is turned OFF and unplugged from the power adapter before taking the battery out.
    • Use the Phillips #1 screwdriver to remove the five 6 mm screws holding the battery in place along the edges of the battery.
  7. Dell Latitude 7390 (2-in-1) Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 7390 (2-in-1) Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 7390 (2-in-1) Fan Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful not to break the connector by pulling too hard on the black tab.
    • Pull the black tab on the top of the connector to unplug the battery from the motherboard.
  8. Dell Latitude 7390 (2-in-1) Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the battery out of the laptop.
  9. Dell Latitude 7390 (2-in-1) Fan Replacement, Fan: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five black screws holding the fan and heatsink in place using the Phillips #0 screwdriver.
  10. Dell Latitude 7390 (2-in-1) Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers or your fingers to disconnect the fan connector.
  11. Dell Latitude 7390 (2-in-1) Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fan from the case.
Glennjay Elayda
crwdns2935283:002/22/22crwdne2935283:0
288 crwdns2915208:0crwdne2915208:0
Clemson, Team 1-4, Hunter Spring 2022 crwdns2935289:0Clemson, Team 1-4, Hunter Spring 2022crwdne2935289:0
CLEM-HUNTER-S22S1G4
Wonderful!! :)
Since a couple of weeks, my laptop is heating up to 95 degrees even when noting much is going on. I wanted to have it fixed, but I don't have hundreds of dollars to spend to fix a laptop that (in apparence) works just fine. But I know it's not smart, and it keeps stressing me out.
With the step-by-step explanations and photos, it doesn't look hard at all to do it by myself... and the replacement part is like<30-50$ on Dell's website! Hallelujia!!
Thanks a lot!!
*The only thing that would be nice to add is the model name/number of the heatsink or fan that I need to use to make the replacement (the heatsink isn't mentioned in the parts that you need).
Sara Xa - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 73
crwdns2942667:0crwdne2942667:0 3,688
