Dell Latitude 5521 Memory Replacement
  1. Dell Latitude 5521 Memory Replacement, Base Cover Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 5521 Memory Replacement, Base Cover Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 5521 Memory Replacement, Base Cover Removal: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 9 phillips #0 screws from the bottom of the case.
    • Carefully pry open the base cover with your spudger. Work your way around the case slowly, being careful not to damage any of the components inside.
    • Once removed you will have access to the contents of your case.
  2. Dell Latitude 5521 Memory Replacement, Memory Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 5521 Memory Replacement, Memory Removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 5521 Memory Replacement, Memory Removal: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate Memory on the mainboard.
    • Gently push the retention clips away from the memory module. Once you have both clips pushed away the memory module will "pop-up" on it's own.
    • Pull the memory module away from the mainboard.
Michael Engle
crwdns2935283:010/14/21crwdne2935283:0
461 crwdns2915208:0crwdne2915208:0
Thanks, this helped me! I noted a few things:
1.some of the screws are a little hard to get out, I think because they have lock-tite, it acts as a retainer. They had to be pulled while also unscrewing.
2.I used the iFixit bladed halberd, to pry of the case without breaking the clips. I know it's not as common of a tool, but the ultra thing blade worked well to disengage the clips gently.
3. My single 16GB DIMM wasn't cutting it. All physical memory was exhausted by the time I booted and loaded one Office file. I added a 4GB PC4-2666MHZ I had lying around, and it worked. Mixing and matching isn't recommended, but it worked in my case. Hopefully now I have some breathing room for running apps. PC/Mac vendors should stop selling units with 16GB or less. It simply isn't enough for a modern Mac or Windows (but does work fine for Linux).
Chris Alleyne-Levy - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 679
