- Here is a possible solution for fixing the error "The Processor Fan failed to respond correctly"
- Often fans are dusted and dirty and therefore they wirk no longer properly.
- Symptomatics would be an extremely slow work, sudden switching off by overheating, etc
Turn off your computer
Turn on and constantly tapping F12
in the pre-boot menu choose "Diagnostics".
The Troubleshooting solved the specified error code 2000-0511.
place the laptop upside down on a soft, clean surface to avoid scratching
locate the screws (in this case 8)
use the screwdriver
'Note: the screws are designe to stay attached in the back cover even after being unscrewed. This prevents loss.'
use the opening tool to open the back cover starting on the hinge areas. then move slowly around the edges
lift the open areas with your hand (lightly!) and slowly work using the tension along the edges.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the fan connector
Loosen 2x M2 screws remove the fan
Loosen 3x small slotted screws
Remove all possible dirt and dust (With the help of tweezers, compressed air, brush)
Try to rotate the Fan with your fingers slowly
