Dell Latitude 3450 RAM Replacement
crwdns2869540:0crwdne2869540:0: 4.2K
2
18
95
4,203
crwdns2959984:0crwdne2959984:0: 2
crwdns2959974:02crwdne2959974:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:015crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
crwdns2944444:0crwdne2944444:0
crwdns2944446:0crwdne2944446:0
  • ×2
    RAM (DDR3)
    This laptop supports up to 8GB per RAM slot, with 2 RAM slots
crwdns2936621:0crwdne2936621:0
    1. Dell Latitude 3450 RAM Replacement, Getting Started: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 3450 RAM Replacement, Getting Started: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Ensure the laptop is powered off .
      • Flip the laptop over.
    2. Dell Latitude 3450 RAM Replacement, Removing the Rear Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 3450 RAM Replacement, Removing the Rear Cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 3450 RAM Replacement, Removing the Rear Cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Loosen the two Phillips head screws.
      • These screws should back out, but should not actually be removable.
      • Locate the indent on the rear cover half way between the two Phillips head screws.
      • Insert your spudger to help pry up the rear cover.
      • It may be necessary to run the spudger along the side with the indent to help release the clips
      • Lift off the rear cover.
    3. Dell Latitude 3450 RAM Replacement, Installing the RAM: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 3450 RAM Replacement, Installing the RAM: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 3450 RAM Replacement, Installing the RAM: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The RAM slots are in line with the hard drive, and on the right side if the cover was opened away from you.
      • Please note that there are A and B RAM Slots. There must be a RAM chip in the A Slot, or the laptop will not load normally.
      • The Slots are labeled on the board, under where the chips would normally be seated.
      • Ensure that the space in the RAM chip lines up with alignment pin on the slot.
      • Insert the RAM chip at approximately at 45° angle.
      • Once the chip bottoms out on the slot, push down on the opposite side from the pins until the RAM chip seats on the board.
      • Depending on your machines current configuration, you may need to remove a RAM chip before you can insert your new ones.
      • Using your finger nail or a spudger, push the lock clips off the RAM chip.
      • Normally the clips can be done one at a time, but may require you to release both at once.
      • Once released, the chip should spring up and can be removed.
crwdns2935291:0crwdne2935291:0
Matt
151 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 95
crwdns2959996:0crwdne2959996:0 4,203
