crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Dell KB212-Bcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Dell KB212-B Teardown, Remove Screws from Back: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 12 screws from the back of the keyboard with a #2 Phillips screwdriver
  2. Dell KB212-B Teardown, Remove Screws from under Rubber Feet: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell KB212-B Teardown, Remove Screws from under Rubber Feet: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell KB212-B Teardown, Remove Screws from under Rubber Feet: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 2 rubber feet from the keyboard using a screw driver
    • Remove the screws under the rubber feet using a #2 Phillips screw driver. There is 1 screw under each foot for a total of 2 screws.
  3. Dell KB212-B Teardown, Split the Plastic Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell KB212-B Teardown, Split the Plastic Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to split the plastic shells by running it along the exterior of the plastic frame on all four sides of the keyboard shell. When the portion of the plastic shell is successfully unconnected, a clicking sound is heard.
  4. Dell KB212-B Teardown, Key Removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove an individual key, take a small pair of pliers or tweezers and squeeze the two tabs while gently applying pressure until the key is popped out.
  5. Dell KB212-B Teardown, Accessing the controller PCB: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Phillip screws and the thin piece of bracketing metal to access the controller PCB
  6. Dell KB212-B Teardown, Removing the Controller: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell KB212-B Teardown, Removing the Controller: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell KB212-B Teardown, Removing the Controller: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull back or remove the thin plastic membrane and the three translucent flexible PCBs to gain full access to the controller.
    • Using a pair of tweezers, remove the USB wire header
    • Gently press the plastic clip retaining the PCB and then pull on one of the PCB edges to remove.
Drew Miller
crwdns2935283:011/16/19crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
crwdns2947412:05crwdne2947412:0
thank you very much. cleaned an old keyboard of mine.
little-gimmick - crwdns2934203:0crwdne2934203:0
Was really confused why my keyboard wasn't coming apart till I read this guide. Turns out it was just the screw under those little rubber feet. Thanks for the guide!
ArrowSwift - crwdns2934203:0crwdne2934203:0
very very helpful thank you
Albert - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 132
crwdns2942667:0crwdne2942667:0 8,478
