Press the tab on the stand cover and lift up.
Remove the four phillips screws that attach the stand to the computer.
Tilt the stand up and out.
Starting from the optical drive, pry the back cover up with a plastic spudger.
Remove the three screws that hold the hard drive cage to the chassis.
Slide the hard drive cage out slightly to access and remove the power and SATA cable.
Lift the hard drive cage out.
Remove the four screws (two on each side) that attach the hard drive cage to the hard drive.
Lift the hard drive cage off the hard drive.
crwdns2935229:035crwdne2935229:0
Thanks for this info this is very useful
Thank you once again
Good Job, short and sweet and easy to follow
Really useful information thank you.
