Dell Inspiron N5030 Keyboard Replacement
  1. Dell Inspiron N5030 Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron N5030 Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the computer over on its back so the battery compartment faces towards you.
    • Place your fingers on the small buttons with arrows pointing outwards.
    • Push and slide the buttons outward to unlock the battery compartment.
  2. Dell Inspiron N5030 Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron N5030 Keyboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the battery and pull it towards yourself.
    • Remove the battery.
  3. Dell Inspiron N5030 Keyboard Replacement, Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
  4. Dell Inspiron N5030 Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip over the laptop and open it so that the screen faces you.
  5. Dell Inspiron N5030 Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool and your fingers to pry off the top panel.
    • Pry the panel off starting at any one of the corners and then continue around the edges of the computer.
  6. Dell Inspiron N5030 Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be careful when lifting off the keyboard panel. There are multiple delicate cables connecting the panel to the motherboard.
    • Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
  7. Dell Inspiron N5030 Keyboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
  8. Dell Inspiron N5030 Keyboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
  9. Dell Inspiron N5030 Keyboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top keyboard panel.
crwdns2935229:05crwdne2935229:0
Gunnar Salazar
crwdns2935283:009/30/13crwdne2935283:0
128 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-59, Amido Spring 2014 crwdns2935289:0Cal Poly, Team 10-59, Amido Spring 2014crwdne2935289:0
CPSU-AMIDO-S14S10G59
What if i broke the blue ribbons connection to the keyboard
oibrahimopeyemi - crwdns2934203:0crwdne2934203:0
This solution is quite troublesome and does not explain how to disconnect / re-connect the wide flat keyboard cable. For a simpler solution see :
https://www.youtube.com/watch?v=jWuGb9AA...
Agropecuaria El Sinu - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 2,880
