Dell Inspiron N4010 Motherboard Replacement
  1. Dell Inspiron N4010 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the laptop is not plugged into any wall outlets or the charger
    • Unlock the battery by sliding the right-hand switch to the right.
  2. Dell Inspiron N4010 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron N4010 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While holding the left-hand switch to the left position, pull the battery away from the laptop.
  3. Dell Inspiron N4010 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery is now fully removed and the laptop will not power on without it.
  4. Dell Inspiron N4010 Motherboard Replacement, Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron N4010 Motherboard Replacement, Keyboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron N4010 Motherboard Replacement, Keyboard: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the #0 Philips head, unscrew the indicated screw.
    • Carefully pull the RAM cover up and away.
  5. Dell Inspiron N4010 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the indicated 5.7mm screw beneath the RAM Cover.
    There Is one More screw that needs to be removed!!!
    Guillermo Zepeda - crwdns2934203:0crwdne2934203:0
    • Remove another screw above the battery release tab
  6. Dell Inspiron N4010 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron N4010 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away.
    • Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
  7. Dell Inspiron N4010 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron N4010 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop.
    • Be careful not to put stress on the ribbon cable below.
  8. Dell Inspiron N4010 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron N4010 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully unclip the ribbon cable by tipping the keyboard towards the screen.
    • The keyboard is now completely disconnected.
  9. Dell Inspiron N4010 Motherboard Replacement, Palm Rest Assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron N4010 Motherboard Replacement, Palm Rest Assembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the indicated 5.7mm screws.
    • Remove the smaller 3mm screws from underneath the battery compartment.
    On the one I worked on there where 3 screws above the disk drive which caused the shroud to break. Make use to remove the disk drive and take out the screws before proceeding to the next step
    Alexander Whitney - crwdns2934203:0crwdne2934203:0
  10. Dell Inspiron N4010 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron N4010 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a plastic spudger, pry away the silver top cover from the black casing.
    • Move the tool to the right and left along the seams to fully disconnect the cover.
  11. Dell Inspiron N4010 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the indicated ribbon cables underneath where the keyboard sits.
  12. Dell Inspiron N4010 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the cover upwards and away from the body of the laptop, after removing the optical drive and unscrewing the three screws on the right.
    My same product does not have an open top because there are three screws in the ODD….ㅠㅠ
    김옥현 - crwdns2934203:0crwdne2934203:0
  13. Dell Inspiron N4010 Motherboard Replacement, Fan: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron N4010 Motherboard Replacement, Fan: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back the yellow tape to expose the ribbon connector.
    • Unplug the ribbon cable from the motherboard.
  14. Dell Inspiron N4010 Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the 3-wire connector from the motherboard.
  15. Dell Inspiron N4010 Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the indicated 5.6mm screws with the #0 Phillips Head Screwdriver.
  16. Dell Inspiron N4010 Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fan from the device.
    Aluminum flux cable isn’t attached to fan assembly
    Daniel Sledge - crwdns2934203:0crwdne2934203:0
    On bottom right to remove the driver gently slide the entire assembly to the right it will come out in one piece
  17. Dell Inspiron N4010 Motherboard Replacement, Motherboard: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron N4010 Motherboard Replacement, Motherboard: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two screws on the right hand speaker with the #0 Phillips Head.
    • Unplug the speaker connector from the motherboard.
  18. Dell Inspiron N4010 Motherboard Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reaching under the daughter board, disconnect the connector.
    • It will be under the board in the area indicated.
  19. Dell Inspiron N4010 Motherboard Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the indicated 5.6mm screws with a Phillips #0 screwdriver.
    Incorrect screw removal info. Under and to the right of B3 no screw until further assembly.
    derek hale - crwdns2934203:0crwdne2934203:0
    The screws are numbered B1-B9 on the motherboard. There are three along the front edge not marked in this photo. The DVD drive screw is marked in this photo but it was removed previously.
    Wayne Sander - crwdns2934203:0crwdne2934203:0
  20. Dell Inspiron N4010 Motherboard Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The motherboard can now be removed by pulling upwards, tilting it to the left of the laptop until the connectors clear the body of the laptop.
Jonathan Sellier
crwdns2935283:009/26/17crwdne2935283:0
952 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S13-G5, Boczar Fall 2017 crwdns2935289:0USF Tampa, Team S13-G5, Boczar Fall 2017crwdne2935289:0
USFT-BOCZAR-F17S13G5
Please before removing the keyboard you should remove all the back screws because a couple of them are attached to the keyboard.
rpmarcolin - crwdns2934203:0crwdne2934203:0
Also before removing the palm rest, you should remove the 6 M2x3 screws where the battery is located.
Hi, the top left screw on the motherboard (just to the right of the fan) is different than the others. What type of screwdriver do I need for this one?
Michael del Rio - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,078
