Use this guide to replace the keyboard on your Dell Inspiron Mini 1012 laptop.
The keyboard is used to directly put information into your laptop, meaning a broken or non-working keyboard can render a laptop unusable. When a keyboard is failing, it's common to see keys that aren't working, repeating itself, or coming out with a different output.
Unlock the two tabs on the bottom of the laptop.
Use your fingernail or a spudger to pull the battery pack out of the laptop.
Remove the three screws with a Phillips #00 screwdriver.
Insert the spudger between the top of the keyboard and the laptop body.
Carefully pry the keyboard up.
Unlock the connector to release the ribbon cable.
Carefully pull on the clear tab to remove the keyboard from the device.
Lay the keyboard back onto the device and gently snap it back into place.
To reassemble your device, follow these instructions in reverse order starting at step two.
