Dell Inspiron M5030 RAM Replacement
  1. Dell Inspiron M5030 RAM Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron M5030 RAM Replacement, Keyboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all fourteen Phillips #0 7/16" screws from the bottom of the laptop.
    • Remove the two Phillips #0 5/16" screws from the bottom of the laptop.
  2. Dell Inspiron M5030 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron M5030 RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the laptop over and open the lid.
    • Locate the three tabs above the first row of keys on the top of the keyboard, found above the F1, F6, and PrntScr keys.
    • With one of your hands, push the leftmost tab down with the plastic opening tool (above the F1 key). With your other hand, lift the left side of the keyboard.
    • Push the middle tab down with the plastic opening tool and continue lifting from the left side of the keyboard to the right side (above the F6 key).
    • Push the rightmost tab down with the plastic opening tool and continue lifting from the left side of the keyboard to the right side (above the PrntScr key). The keyboard should be loosened from the laptop after these steps.
  3. Dell Inspiron M5030 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron M5030 RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After the top edge of the keyboard is loose, pull up on the keyboard gently.
    • Do not pull the keyboard up forcefully as the keyboard is still attached to the laptop by a ribbon.
  4. Dell Inspiron M5030 RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron M5030 RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron M5030 RAM Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up the bottom side of the keyboard and locate the ribbon connecting the keyboard to the motherboard.
    • Locate the blue end of the ribbon which is connected to the motherboard.
    • Lift up the black flap on the connector and gently pull the ribbon away from the connector which is parallel to the motherboard.
    • Lift the keyboard up and off of the motherboard. Detach the blue end of the ribbon from the connector.
  5. Dell Inspiron M5030 RAM Replacement, RAM: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron M5030 RAM Replacement, RAM: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron M5030 RAM Replacement, RAM: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the two blue chips in the middle of the computer. These are the computer's RAM (Random Access Memory) chips.
    • Push outward on the metal tabs on the short ends of the upper RAM chip to loosen it. The left end of the chip should lift up, putting the chip at an angle.
    • Grab the lifted left edge of the RAM with your fingers, and gently slide it out.
  6. Dell Inspiron M5030 RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron M5030 RAM Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron M5030 RAM Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push outward on the metal tabs on the short ends of the lower RAM chip to loosen it. The left end of the chip should lift up, putting the chip at an angle.
Ryan Moelter
crwdns2935283:004/17/14crwdne2935283:0
382 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-44, Maness Spring 2014 crwdns2935289:0Cal Poly, Team 3-44, Maness Spring 2014crwdne2935289:0
CPSU-MANESS-S14S3G44
This is BY FAR the nicest and the most resourceful set of instructions for anything about any thing on the internet so far. And thrust me, when i say so far, it is a loooong time.
So, coincidentally i just gave my youngest (6 y.o.) this DELL Inspirion M5030 to play on it. Bu i really hate to disassemble it again just to look at the RAM module.
Can you help me and tell me which type it is there?
Is it possible that it is "just RAM" as the pre DDR2 type?
Ozren Kartalović - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 2,175
