Dell Inspiron Duo RAM Replacement
  1. Dell Inspiron Duo RAM Replacement, Front Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron Duo RAM Replacement, Front Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
    • To remove the old battery from the laptop, first unscrew the eight screws (size M2.5x8) from the bottom with a Phillips #0 screwdriver, this will allow the removal of the keyboard and front panel.
    There are seven screws, not eight. You need to slide away to cover to get to the seventh screw near the Windows 7 label.
    There are two more screws (in the bottom of the picture) that need to be removed before the top cover can be removed.
    Chiel Kersten - crwdns2934203:0crwdne2934203:0
    What is the battery name or number for replacement?
    Emma Cabrera - crwdns2934203:0crwdne2934203:0
    Also remove the 2 screws under the slide away at the bottom of the picture is they are present
    Gresh - crwdns2934203:0crwdne2934203:0
    Battery is marked as "Type WW12P"
  2. Dell Inspiron Duo RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron Duo RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device over again and open the laptop so that you have access to the keyboard. There are hooks on the bottom of the keyboard, but gently pulling the keyboard towards the monitor will allow it to pull out easily. Be sure to unclamp the ribbon cable. Remove the three screws under the keyboard.
    • Remove the three plastic Keyboard and trackpad connectors (these are labeled with a blue circle on the second photograph).
    The keyboard cable clamp opens toward you on a hinge
  3. Dell Inspiron Duo RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron Duo RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Next, remove the top cover from the device using the plastic opening tools. It snaps in on the sides, so don't worry if you hear it unsnapping; it's not breaking.
    Before trying to remove the top cover, make sure to remove the 4 srcews that were hidden under the keyboard and also two additional screws on the bottom, otherwise you will damage the top cover. If you remove all the screws, the cover will come off a lot easier :-)
  4. Dell Inspiron Duo RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the cover removed, locate the 2GB RAM stick. It will be in the upper-middle portion of the device. The RAM stick is the flat blue rectangular object that has four black squares running along it vertically (for convenience, the RAM stick has been outlined in red in the photo).
  5. Dell Inspiron Duo RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron Duo RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are two white spring levers on either side of the RAM. Pull them out gently to release the RAM. This will cause the RAM to stick up at a forty-five degree angle.
    • With the RAM at a forty-five degree angle, gently pull it straight out of the device.
  6. Dell Inspiron Duo RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron Duo RAM Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the RAM stick flipped up, carefully lift it out of the slot.
Steven Luther
crwdns2935283:006/23/15crwdne2935283:0
778 crwdns2915208:0crwdne2915208:0
UW Tacoma, Team 1-1, Liner SU 2015 crwdns2935289:0UW Tacoma, Team 1-1, Liner SU 2015crwdne2935289:0
UWT-LINER-SU15S1G1
Good effort, but incomplete. Laptop parts can be very easily damaged, so removing all the screws is important.
Good evening!!!
Is it possible to install a M.2 or NVME SSD in this netbook model?
Greetings and blessings from Venezuela!!!!
Edwin Guerra Avendaño - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 2,284
