In this guide, we'll walk you through how to remove the original battery from the Dell Inspiron Duo laptop and replace it with a new one.
Flip your device over so the bottom panel is facing up.
To remove the old battery from the laptop, first unscrew the eight screws (size M2.5x8) from the bottom with a Phillips #0 screwdriver, this will allow the removal of the keyboard and front panel.
Flip the device over again and open the laptop so that you have access to the keyboard. There are hooks on the bottom of the keyboard, but gently pulling the keyboard towards the monitor will allow it to pull out easily. Be sure to unclamp the ribbon cable. Remove the three screws under the keyboard.
Remove the three plastic Keyboard and trackpad connectors (these are labeled with a blue circle on the second photograph).
Next, remove the top cover from the device using the plastic opening tools. It snaps in on the sides, so don't worry if you hear it unsnapping; it's not breaking.
Before trying to remove the top cover, make sure to remove the 4 srcews that were hidden under the keyboard and also two additional screws on the bottom, otherwise you will damage the top cover. If you remove all the screws, the cover will come off a lot easier :-)
Remove the cover, and locate the battery. The battery can be found in the lower portion of the device. It will have a blue Li-ion Recycling symbol on the right half, and "Dell Inc. Dell Battery Module" on the left side.
Remove the two screws from the bottom center of the battery, the two screws from the top outside corners, and the single screw in the top-center.
Lastly, remove the white power connector that attaches the battery to the motherboard ( to make this easier to see, the power connector is outlined in red in the photograph). Now remove the battery from the device and place to the side.
I would take the opportunity to give the insides a good clean especially the CPU fan and the 2 speakers bottom left/right in the picture above. the speakers lift a bit and allow you to blow away all the crud.
crwdns2935229:08crwdne2935229:0
i want the battery my email is engkaim95@gmail,com
There are seven screws, not eight. You need to slide away to cover to get to the seventh screw near the Windows 7 label.
There are two more screws (in the bottom of the picture) that need to be removed before the top cover can be removed.
Chiel Kersten - crwdns2934203:0crwdne2934203:0
What is the battery name or number for replacement?
Emma Cabrera - crwdns2934203:0crwdne2934203:0
Also remove the 2 screws under the slide away at the bottom of the picture is they are present
Gresh - crwdns2934203:0crwdne2934203:0
Battery is marked as "Type WW12P"
