This guide contains step-by-step instructions on how to replace the trackpad and surrounding area on a Dell Inspiron 9300 laptop.
To complete this guide, you will need a heavy-duty spudger and a 64-bit driver Kit.
Whether your trackpad is malfunctioning or you simply need to install a new one, following these directions will help you complete the replacement process safely and effectively!
Remove the battery in to order avoid damaging internal components.
Remove the twelve 6mm Phillips screws from the bottom of the case.
Gently pry away the silver bezel above the keyboard and below the display using a spudger.
Remove the two 5mm Phillips screws retaining the keyboard.
Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward, away from the motherboard.
Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
Remove the seven 6mm Phillips screws holding the trackpad/palm rest to the motherboard.
Gently pry the CMOS battery out of its retaining clip using a spudger.
Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger.
Remove the trackpad ribbon cable from the motherboard using a spudger.
Pull up and away on the upper case to remove.
