Dell Inspiron 9100 Memory Replacement
crwdns2869540:0crwdne2869540:0: 4141
2
27
100
4,141
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2959986:0crwdne2959986:0: 3
crwdns2959982:03crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931273:0crwdne2931273:0
This guide will help you replace the RAM (memory module) on your Dell Inspiron 9100. It is useful to replace the RAM if your computer runs slower than normal or if your programs constantly freeze.
This guide requires a Phillips #00 screwdriver.
    1. Dell Inspiron 9100 Memory Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 9100 Memory Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 9100 Memory Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unplug the laptop from the power adapter and turn the power off.
      • Failure to unplug laptop before proceeding could result in risk of electric shock!
    2. Dell Inspiron 9100 Memory Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 9100 Memory Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 9100 Memory Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slide the battery-lock tab and hold.
      • Flip the battery away from the chassis to remove it.
    1. Dell Inspiron 9100 Memory Replacement, Memory: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 9100 Memory Replacement, Memory: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the Philips #00 screwdriver, undo the screw on the memory module cover, labeled "M."
      • This screw will remain in the panel.
      • Pull the cover away from the laptop using your finger.
    2. Dell Inspiron 9100 Memory Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 9100 Memory Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 9100 Memory Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use your fingertips to carefully spread apart the plastic white tabs.
      • Flip the RAM up at a 45 degree angle and remove it.
      • Hold the RAM by the edges only.
      • Ground yourself while dealing with RAM. Static shock can damage the memory. Store the RAM in an anti-static bag while it is not in use.
    3. Dell Inspiron 9100 Memory Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Repeat step four with the second RAM.
charlierefvem
crwdns2935283:001/11/11crwdne2935283:0
854 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-2, Forte Winter 2011 crwdns2935289:0Cal Poly, Team 13-2, Forte Winter 2011crwdne2935289:0
CPSU-FORTE-W11S13G2
crwdns2935297:096crwdne2935297:0
crwdns2936753:030crwdne2936753:0 100
crwdns2959996:0crwdne2959996:0 4,141
