This guide requires a Phillips #00 screwdriver
Unplug the laptop from the power adapter and turn the power off.
Slide the battery-lock tab and hold.
Flip the battery away from the chassis to remove it.
Use your fingers to gently pull up on the hinge covers. They will release with an audible snap.
Fold the screen back to 180 degrees.
Using your index fingers, pull up the hinge cover.
After the hinges pop, pull the hinge cover gently.
Pull the clear tab on the right side of the laptop up. This tab will disconnect the hinge cover from the laptop.
Remove the two 3mm screws on the top of the keyboard (nearest to the screen)
Tilt the keyboard away from the screen.
Pull up on the white tab underneath the keyboard to release the keyboard.
