Dell Inspiron 8600 Upper Case Replacement
  1. Dell Inspiron 8600 Upper Case Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Upper Case Replacement, Hinge Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 8600 Upper Case Replacement, Hinge Cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 8600 Upper Case Replacement, Hinge Cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Upper Case Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Upper Case Replacement, Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 8600 Upper Case Replacement, Keyboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 8600 Upper Case Replacement, Keyboard: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
    • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
    • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
    • The keyboard should be easily removable at this point.
  5. Dell Inspiron 8600 Upper Case Replacement, Display Module: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 8600 Upper Case Replacement, Display Module: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  6. Dell Inspiron 8600 Upper Case Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  7. Dell Inspiron 8600 Upper Case Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 8600 Upper Case Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the display module directly upwards from the base of the computer.
  8. Dell Inspiron 8600 Upper Case Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now remove the display module.
  9. Dell Inspiron 8600 Upper Case Replacement, Upper Case: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 8600 Upper Case Replacement, Upper Case: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screws that hold the upper case.
    • You can now pop up the upper case and replace.
John Nesthus
crwdns2935283:004/13/11crwdne2935283:0
186 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-22, Garner Spring 2011 crwdns2935289:0Cal Poly, Team 18-22, Garner Spring 2011crwdne2935289:0
CPSU-GARNER-S11S18G22
crwdns2942667:0crwdne2942667:0 2,688
