Dell Inspiron 8600 Lower Case Replacement
    1. Dell Inspiron 8600 Lower Case Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery from the bottom left of the laptop as shown.
      • Remove the battery before operating on the computer to avoid electrocution.
    1. Dell Inspiron 8600 Lower Case Replacement, Hinge Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 8600 Lower Case Replacement, Hinge Cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 8600 Lower Case Replacement, Hinge Cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
      • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
      • Be careful of the wire attached to the underside of the hinge cover.
    2. Dell Inspiron 8600 Lower Case Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the small black tab on the right hand side of the laptop.
      • You have now removed the hinge cover.
    1. Dell Inspiron 8600 Lower Case Replacement, Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 8600 Lower Case Replacement, Keyboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 8600 Lower Case Replacement, Keyboard: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
      • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
      • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
      • The keyboard should be easily removable at this point.
    1. Dell Inspiron 8600 Lower Case Replacement, Display Module: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 8600 Lower Case Replacement, Display Module: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the laptop over and remove the indicated screws.
      • Flip the laptop back over.
      • Find the two places where the display module is attached to the base of the computer.
    2. Dell Inspiron 8600 Lower Case Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the video card from the display module by gently lifting upwards on the black tab.
    3. Dell Inspiron 8600 Lower Case Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 8600 Lower Case Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the display module directly upwards from the base of the computer.
    4. Dell Inspiron 8600 Lower Case Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Now remove the display module.
    1. Dell Inspiron 8600 Lower Case Replacement, Lower Case: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two screws holding down the upper case with a Phillips #1 screwdriver.
    2. Dell Inspiron 8600 Lower Case Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 8600 Lower Case Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a Phillips #1 screwdriver, remove four screws attaching the metal bar to the motherboard.
      • Remove the metal bar which connects the motherboard to the lower case.
    3. Dell Inspiron 8600 Lower Case Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the optical disk drive by gently pulling upward on the plastic connector to prevent connection damage.
    4. Dell Inspiron 8600 Lower Case Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 8600 Lower Case Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 8600 Lower Case Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the optical disc drive by pushing a small release button on the side of the laptop and then pulling it.
      • This will uncover one final screw. Use the Phillips # 1 to remove the screw.
    5. Dell Inspiron 8600 Lower Case Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Now, pop off the lower case for repair or replacement.
John Nesthus
crwdns2935283:004/13/11crwdne2935283:0
186 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-22, Garner Spring 2011 crwdns2935289:0Cal Poly, Team 18-22, Garner Spring 2011crwdne2935289:0
CPSU-GARNER-S11S18G22
crwdns2935297:0180crwdne2935297:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 4,029
