Dell Inspiron 8600 LCD Replacement
  1. Dell Inspiron 8600 LCD Replacement, Hinge Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 8600 LCD Replacement, Hinge Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 8600 LCD Replacement, Hinge Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  2. Dell Inspiron 8600 LCD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  3. Dell Inspiron 8600 LCD Replacement, Display Module: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 8600 LCD Replacement, Display Module: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  4. Dell Inspiron 8600 LCD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  5. Dell Inspiron 8600 LCD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 8600 LCD Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the display module directly upwards from the base of the computer.
  6. Dell Inspiron 8600 LCD Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now remove the display module.
  7. Dell Inspiron 8600 LCD Replacement, LCD: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 8600 LCD Replacement, LCD: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 8600 LCD Replacement, LCD: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First, remove the plastic tabs that are covering the interior screws.
    • After removing the tabs, remove the interior screws using a #1 Philips Screwdriver.
    • Note there are 8 tabs and 8 screws in total.
  8. Dell Inspiron 8600 LCD Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now that the screws are removed, press the plastic casing inward to loosen the case. Then remove the plastic case from the monitor unit.
  9. Dell Inspiron 8600 LCD Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Philips #1 screwdriver remove the screws holding the LCD in place.
    • Note there are 8 screws in total for this step, 4 on each side of the unit.
  10. Dell Inspiron 8600 LCD Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the broken LCD unit, and replace with new unit.
Perry
crwdns2935283:004/12/11crwdne2935283:0
251 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-22, Garner Spring 2011 crwdns2935289:0Cal Poly, Team 18-22, Garner Spring 2011crwdne2935289:0
CPSU-GARNER-S11S18G22
which controller board do i have to use for this model ?
bcdoor - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 79
crwdns2942667:0crwdne2942667:0 4,977
