Dell Inspiron 7586 2-in-1 SSD Replacement
  1. Dell Inspiron 7586 2-in-1 SSD Replacement, SSD: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 7586 2-in-1 SSD Replacement, SSD: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 7586 2-in-1 SSD Replacement, SSD: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the laptop over so the bottom is facing up.
    • Use a Phillips #00 screwdriver to remove nine screws from the back case.
    • Insert an opening tool or spudger in the seam between the back case and the body of the laptop.
    • Work your way around the perimeter of the laptop and release the clips that secure the back case.
    • You will hear a clicking sound as the the clips are released and the back case is being removed.
    • Remove the back case.
  2. Dell Inspiron 7586 2-in-1 SSD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 7586 2-in-1 SSD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 7586 2-in-1 SSD Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the single screw securing the NVME drive.
    • Once the screw is removed, the SSD should pop up.
  3. Dell Inspiron 7586 2-in-1 SSD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 7586 2-in-1 SSD Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 7586 2-in-1 SSD Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently slide the SSD out of the slot.
    • Make sure to gently pull out the drive to avoid damaging the M.2 slot where you insert the new SSD.
  4. Dell Inspiron 7586 2-in-1 SSD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 7586 2-in-1 SSD Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Align the tooth edge of the SSD with the indents on the drive socket and gently insert the replacement SSD.
    • Press down on the SSD so the screw hole and drive align.
    • Use a Phillips #00 screwdriver to replace the screw.
    • Don't be scared to push down on the SSD as it should be level with the rest of the components.
Mike03
crwdns2935283:003/05/24crwdne2935283:0
139 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 7-1, Grodsky Spring 2024 crwdns2935289:0CSU Los Angeles, Team 7-1, Grodsky Spring 2024crwdne2935289:0
CSULA-GRODSKY-S24S7G1
crwdns2942667:0crwdne2942667:0 379
