Dell Inspiron 7568 Keyboard Replacement Guide
    1. Dell Inspiron 7568 Keyboard Replacement Guide, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 7568 Keyboard Replacement Guide, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the ten 7mm Phillips #1 screws on the bottom cover.
      • Remove the bottom cover.
    2. Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four 3mm Phillips #1 screws holding the battery.
      • Unhinge the connector cable to the battery.
      • Remove the battery.
    1. Dell Inspiron 7568 Keyboard Replacement Guide, Display Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 7568 Keyboard Replacement Guide, Display Assembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew & remove the two 3mm screws (using a ph1 screwdriver bit) and the cable bracket, above the motherboard
      • Doing this will allow one to access the LCD-motherboard connector cables.
    2. Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew the 7mm screws that secure the left and right hinges (using a ph1 screwdriver bit).
    3. Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Disconnect the antenna cable (under the left hinge)
      • Disconnect the LCD and Touchscreen display cables under the right hinge.
      • These are a set of two cables. For better image see image two in step one of this guide.
    4. Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully separate the screen from the bottom half of the device.
    1. Dell Inspiron 7568 Keyboard Replacement Guide, Cooling Fan: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 7568 Keyboard Replacement Guide, Cooling Fan: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Begin by unclipping the cable connecting the fan and the motherboard.
      • Gently separate the motherboard cable from the clamp at the bottom of the fan.
      • Remove the cable.
    2. Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two 3mm Phillips #1 screws that hold the fan into place.
      • Remove the fan.
    1. Dell Inspiron 7568 Keyboard Replacement Guide, Keyboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 7568 Keyboard Replacement Guide, Keyboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 7568 Keyboard Replacement Guide, Keyboard: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Once the battery, screen, cooling fan, trackpad are out, the device would resemble the one in the first picture of this step.
      • Unscrew the three screws connecting the copper pipe to the motherboard.
      • Remove the copper pipe.
    2. Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unscrew the three 2mm wafer screws holding the motherboard.
      • Unplug the DC cable from the motherboard.
    3. Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unplug the connecting strip
    4. Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unplug the hard-drive cable
      • Remove the motherboard
    5. Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew the three 3mm screws holding the hard drive (using a ph1 screwdriver bit)
      • Remove the hard drive
    6. Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew the two 3mm screws holding the daughter board (using the ph1 screwdriver bit).
      • Set the daughterboard aside. NOTE: the daughter board doesn't have to be removed
    7. Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew & remove the twenty-eight 2mm bracket screws holding the keyboard bracket (using a PH000 screwdriver bit)
      • Remove the keyboard bracket
    8. Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew & remove the sixteen 2mm screws holding the keyboard (using a PH000 screwdriver bit)
    9. Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 7568 Keyboard Replacement Guide: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unplug the keyboard ("KB") and backlight ("BL") cable
      • Remove the keyboard.
Luis Velez
crwdns2935283:002/19/17crwdne2935283:0
452 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G2, Lacy Spring 2017 crwdns2935289:0USF Tampa, Team S2-G2, Lacy Spring 2017crwdne2935289:0
USFT-LACY-S17S2G2
crwdns2942667:0crwdne2942667:0 1,441
