Dell Inspiron 7568 Display Assembly Replacement Guide
    1. Dell Inspiron 7568 Display Assembly Replacement Guide, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 7568 Display Assembly Replacement Guide, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the ten 7mm Phillips #1 screws on the bottom cover.
      • Remove the bottom cover.
    2. Dell Inspiron 7568 Display Assembly Replacement Guide: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 7568 Display Assembly Replacement Guide: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four 3mm Phillips #1 screws holding the battery.
      • Unhinge the connector cable to the battery.
      • Remove the battery.
    1. Dell Inspiron 7568 Display Assembly Replacement Guide, Display Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 7568 Display Assembly Replacement Guide, Display Assembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew & remove the two 3mm screws (using a ph1 screwdriver bit) and the cable bracket, above the motherboard
      • Doing this will allow one to access the LCD-motherboard connector cables.
    2. Dell Inspiron 7568 Display Assembly Replacement Guide: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 7568 Display Assembly Replacement Guide: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew the 7mm screws that secure the left and right hinges (using a ph1 screwdriver bit).
    3. Dell Inspiron 7568 Display Assembly Replacement Guide: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 7568 Display Assembly Replacement Guide: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 7568 Display Assembly Replacement Guide: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Disconnect the antenna cable (under the left hinge)
      • Disconnect the LCD and Touchscreen display cables under the right hinge.
      • These are a set of two cables. For better image see image two in step one of this guide.
    4. Dell Inspiron 7568 Display Assembly Replacement Guide: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully separate the screen from the bottom half of the device.
Yash Samant
crwdns2935283:002/22/17crwdne2935283:0
406 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G2, Lacy Spring 2017 crwdns2935289:0USF Tampa, Team S2-G2, Lacy Spring 2017crwdne2935289:0
USFT-LACY-S17S2G2
crwdns2942667:0crwdne2942667:0 1,318
