Dell Inspiron 600m LCD Replacement
  1. Dell Inspiron 600m LCD Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 600m LCD Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 600m LCD Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip laptop upside down and locate the battery as shown in the images.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. Dell Inspiron 600m LCD Replacement, LCD: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 600m LCD Replacement, LCD: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using fingernails or a spudger, push any direction on the rubber dots to remove them from the plastic cover.
    • Underneath each rubber dot will be a screw. Remove these screws with the Phillips #00 screwdriver.
  3. Dell Inspiron 600m LCD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 600m LCD Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the IFixit Opening Tool to un-clip the plastic cover, detaching it from the rest of the screen.
    • There are clips about every inch around the right, left, and top of the plastic cover. Be sure that all of them are unclipped.
  4. Dell Inspiron 600m LCD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull straight up on the cover to lift the cover off of the rest of the screen.
    • The bottom part of the plastic is a little sticky.
  5. Dell Inspiron 600m LCD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four screws (two on each side of the screen) with the Phillips #00 screwdriver.
    • The middle screw does not need to be removed.
  6. Dell Inspiron 600m LCD Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the LCD panel off of the base.
    • The LCD is still attached to the computer. Do not pull too hard or you could break the cable.
  7. Dell Inspiron 600m LCD Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 600m LCD Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 600m LCD Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the LCD panel over.
    • Do not touch on or near the back of the panel where it says "Don't Touch." LCD panels contain mercury which is hazardous to humans.
    • Remove the cable by squeezing each side of the connector and gently pulling straight out.
  8. Dell Inspiron 600m LCD Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 600m LCD Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 600m LCD Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the cable at the base of the laptop by pulling up on the yellow tab attached to the cable.
Alex Klimaj
crwdns2935283:004/01/11crwdne2935283:0
143 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-40, Forte Spring 2011 crwdns2935289:0Cal Poly, Team 10-40, Forte Spring 2011crwdne2935289:0
CPSU-FORTE-S11S10G40
crwdns2942667:0crwdne2942667:0 6,989
