This guide will show you how to replace the LCD Screen on the Dell Inspiron 5758.
Prerequisite guides are:
- Battery
- Hard Drive
- DC Jack
- Keyboard
Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
Slide the battery release switch towards the unlock icon.
Lift and pull the ejected battery to remove it.
Remove the one 3mm optical drive screw.
Remove the two 8 mm screws.
Pry up and remove the access door.
Remove the one 3 mm screw.
Remove the bracket.
Unplug the antenna cables.
Remove the Wireless Card.
Unplug the hard drive cable.
Use a plastic opening tool or your fingernail to pop the tab of the cable connector. Then you will be able to disconnect the cable.
Remove the four 8 mm screws.
Remove the hard drive.
Remove the two 3 mm screws under the battery.
Remove the three 2 mm wafer screws under the optical drive.
Remove the ten 8 mm base screws.
Unplug the speaker cable by sliding to the right.
Press in the tabs to loosen the keyboard.
Carefully lift the keyboard up and turn it over.
Unplug the keyboard cable & remove the keyboard.
Slide the DVD optical drive over & remove it from the laptop.
Remove the four 5 mm screws.
Unplug the optical drive interposer cable.
Unplug the power button cable.
Unplug the touchpad cable.
Carefully pry off & loosen the bottom base.
Remove the one 5mm screw.
Lift the circuit board & turn it over.
Unplug the cable.
Remove the audio/USB circuit board.
Loosen the audio / USB cable.
Remove the one 3mm motherboard screw.
Lift the motherboard & carefully move it out of the way.
Unplug the DC jack cable.
Remove the one 3mm screw.
Remove the DC Jack.
Release the antenna cable tape.
Release the antenna cables.
Remove the four 5mm right hinge screws using the Phillips #00 screwdriver.
Remove the three 5mm left hinge screws using Phillips #00 screwdriver.
Open the hinges carefully and remove the LCD display assembly.
Remove the one 2mm wafer screw using Phillips #0 screwdriver.
Loosen the cable and remove the power button circuit board.
Push up on the touchpad to release it from the housing.
Remove the touchpad.
Once you have removed the LCD display assembly from the palmrest touchpad, use a spudger to unsnap the LCD bezel via the notches on the outside edge of the bezel .
When you have removed the LCD bezel, place it to the side.
Lift the LCD screen from the display assembly, flip the LCD screen over, and place the screen face down.
Unplug the LCD cable.
Place the display assembly to the side.
Remove the three 3mm screws that connect each hinge rail to the LCD screen.
Remove the hinge rails.
