This guide is to replace the DC Jack in a Dell Inspiron 5758 laptop. Ensure you have all replacement parts and tools needed for this step-by-step replacement guide.
Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
Slide the battery release switch towards the unlock icon.
Lift and pull the ejected battery to remove it.
Remove the one 3mm optical drive screw.
Remove the two 8 mm screws.
Pry up and remove the access door.
Remove the one 3 mm screw.
Remove the bracket.
Unplug the antenna cables.
Remove the Wireless Card.
Unplug the hard drive cable.
Use a plastic opening tool or your fingernail to pop the tab of the cable connector. Then you will be able to disconnect the cable.
Remove the four 8 mm screws.
Remove the hard drive.
Remove the two 3 mm screws under the battery.
Remove the three 2 mm wafer screws under the optical drive.
Remove the ten 8 mm base screws.
Unplug the speaker cable by sliding to the right.
Press in the tabs to loosen the keyboard.
Carefully lift the keyboard up and turn it over.
Unplug the keyboard cable & remove the keyboard.
Slide the DVD optical drive over & remove it from the laptop.
Remove the four 5 mm screws.
Unplug the optical drive interposer cable.
Unplug the power button cable.
Unplug the touchpad cable.
Carefully pry off & loosen the bottom base.
Remove the one 5mm screw.
Lift the circuit board & turn it over.
Unplug the cable.
Remove the audio/USB circuit board.
Loosen the audio / USB cable.
Remove the one 3mm motherboard screw.
Lift the motherboard & carefully move it out of the way.
Unplug the DC jack cable.
Remove the one 3mm screw.
Remove the DC Jack.
