The Peripheral Component Interconnect (PCI) slot is a built-in slot that allows the attachment of various hardware components on the motherboard of a computer. It can hold different types of cards: network cards, modems, sound cards, disk controllers and other peripherals. As well as a Wi-Fi receiver or Bluetooth.
Unscrew the two large screws in the back holding on the side panel.
Slide the panel backwards to remove it.
The PCI slots are located at the bottom back of the computer.
Unscrew the screw to release the metal piece that holds the cards in place.
Remove metal piece.
Slide the card in the PCI slot up and out.
Take the new card and slide it into the slot that you removed the old one out of.
