Dell Inspiron 1721 Palm Rest Replacement
  1. Dell Inspiron 1721 Palm Rest Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1721 Palm Rest Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 Palm Rest Replacement, Hinge Plate Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1721 Palm Rest Replacement, Hinge Plate Cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1721 Palm Rest Replacement, Hinge Plate Cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
  3. Dell Inspiron 1721 Palm Rest Replacement, Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1721 Palm Rest Replacement, Keyboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1721 Palm Rest Replacement, Keyboard: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove four 3mm Phillips #1 screws from the top of the keyboard.
    • Use an iFixit opening tool to slide the keyboard upwards toward the display.
    • Slide the keyboard until it is clear of the lock tab, and lift it up to remove.
  4. Dell Inspiron 1721 Palm Rest Replacement, Display Assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1721 Palm Rest Replacement, Display Assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the two captive Phillips #0 screws.
    • Remove the cover.
  5. Dell Inspiron 1721 Palm Rest Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the antenna connectors from the WLAN card.
  6. Dell Inspiron 1721 Palm Rest Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1721 Palm Rest Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1721 Palm Rest Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 3mm Phillips #0 screw securing the connector to the case ground.
    • Disconnect the display connector.
    • Disconnect the second connector, then remove the cable from the base.
  7. Dell Inspiron 1721 Palm Rest Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1721 Palm Rest Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1721 Palm Rest Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the display cable from the palm rest.
    • Use a spudger to carefully pull the antenna wires through to front of the device.
  8. Dell Inspiron 1721 Palm Rest Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 1721 Palm Rest Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 3.5 mm Phillips screws that hold the display assembly in place.
    • Lift the assembly straight up to separate it from the body of the device.
  9. Dell Inspiron 1721 Palm Rest Replacement, Back Cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the touch pad connector.
  10. Dell Inspiron 1721 Palm Rest Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1721 Palm Rest Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 1721 Palm Rest Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay the device flat and remove the 17 7mm Phillips #0 screws.
    • Use an iFixit opening tool to separate the back cover.
    • Remove the back cover.
  11. Dell Inspiron 1721 Palm Rest Replacement, Palm Rest: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the palm rest up to remove.
Scott Nadeau
crwdns2935283:009/16/19crwdne2935283:0
423 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S8-G5, Salas Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S8-G5, Salas Fall 2019crwdne2935289:0
ERAU-SALAS-F19S8G5
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 236
