Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement
  1. Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement, Base Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement, Base Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully remove the base cover from the laptop.
  5. Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement, Wireless Card (NIC): crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement, Wireless Card (NIC): crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement, Wireless Card (NIC): crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screw holding down the small bracket for the wireless card using a Phillips #0 screwdriver.
    • Remove the black wired connection from the port over the black triangle.
    • Remove the wire with the white marking from the port above the white triangle.
    • Pull the Wi-Fi card out of its slot.
  6. Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement, Fan: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement, Fan: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the I/O cable.
  7. Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the fan cable from the motherboard.
  8. Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 3 mm screws that secure the fan using a Phillips #0 screwdriver.
  9. Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There is a little piece of tape/sticker on the fan that connects it to the heat sink. Gently remove this.
    • Lift the fan off the palm rest assembly.
  10. Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement, Heatsink: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement, Heatsink: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen seven 3 mm captive screws securing the heatsink to the motherboard using a Phillips #0 screwdriver.
  11. Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the heatsink off the motherboard.
  12. Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement, Display Assembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement, Display Assembly: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Ensure that you have your device opened flat at a 180 degree angle. This will make removal easier.
  13. Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the ribbon cables for the assembly on the right hand side marked "MB1" and "MB2."
    • The "MB1" ribbon is locked with a copper/brass colored handle that must be lifted upwards. Then you can remove the ribbon by pulling it away from the socket.
    • The "MB2" ribbon is locked in its socket with a black latch. Using a non-metallic precision tool (such as tweezers) lift the latch and pull away the MB2 cable.
  14. Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws holding down the assembly on the right hand area using a Phillips #00 screwdriver.
  15. Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screw protecting the endpoints of the NIC cables and NIC chip using a Phillips #0 screwdriver.
    • Gently pull away the cabling from the NIC chip.
    • The wires can be removed without removing the heat sink, though this is not advised if you are not familiar with the layout.
  16. Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws holding down the bracket of the assembly on the left hand side using a Phillips #0 screwdriver.
  17. Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the display assembly upwards away from the palm/main assembly.
  18. Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement, I/O Board (SD and x2 USB ports): crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement, I/O Board (SD and x2 USB ports): crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the latch holding down the ribbon cable on the I/O board, then pull it away using the blue tab.
    • Lift the I/O board upwards to remove it from the assembly.
  19. Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement, Power Button w/ Fingerprint Reader: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement, Power Button w/ Fingerprint Reader: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 17" 7786 2-in-1 Power Button w/ Fingerprint Reader Replacement, Power Button w/ Fingerprint Reader: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the latch holding down the ribbon cable. Remove the cable away from the port.
    • Remove the screw holding down the button in place using a Phillips #0 screwdriver.
    • Grabbing the cushioning of the button, lift it upwards from the assembly.
Antonio Franco
crwdns2935283:008/25/22crwdne2935283:0
1,061 crwdns2915208:0crwdne2915208:0
Gateway, Team 1-3, Class Fall 2022 crwdns2935289:0Gateway, Team 1-3, Class Fall 2022crwdne2935289:0
GCC-CLASS-F22S1G3
crwdns2942667:0crwdne2942667:0 344
