Dell Inspiron 17-5749 Hard Drive Replacement
  1. Dell Inspiron 17-5749 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 17-5749 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Anti-Static Wrist Strap
    $7.95
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 17-5749 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Hard Drive Replacement, Back Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 17-5749 Hard Drive Replacement, Back Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 17-5749 Hard Drive Replacement, Back Cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 5.5mm screws that secure the base cover to the computer's base.
    • Using the plastic opening tool, carefully pry open the base cover starting from the center.
    • Lift the base cover upwards to remove and set it aside.
  4. Dell Inspiron 17-5749 Hard Drive Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 17-5749 Hard Drive Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 17-5749 Hard Drive Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 2.5mm screw that secures the hard-drive assembly to the computer base.
    • Using the pull tab, slide the hard-drive assembly to disconnect it from the system board.
    • Lift the hard-drive assembly off the computer base
Christopher Tran
crwdns2935283:002/13/18crwdne2935283:0
1,162 crwdns2915208:0crwdne2915208:0
Washington State, Team S1-G2, Lobnitz Spring 2018 crwdns2935289:0Washington State, Team S1-G2, Lobnitz Spring 2018crwdne2935289:0
WSU-LOBNITZ-S18S1G2
crwdns2931471:06crwdne2931471:0
crwdns2942667:0crwdne2942667:0 788
