Dell Inspiron 17-3721 Optical Drive Replacement
  1. Dell Inspiron 17-3721 Optical Drive Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 17-3721 Optical Drive Replacement, Keyboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool or a metal spudger to pry out the tabs on top of the keyboard.
    • After prying the tabs up, carefully pull the keyboard out of the laptop.
    • Use caution when prying the tabs up or lifting the keyboard up, as the plastic material and the strip on the keyboard can easily break.
  2. Dell Inspiron 17-3721 Optical Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 17-3721 Optical Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the keyboard is lifted, locate the release tab.
    • Using a plastic opening tool or your finger, lift the tab so that it opens .
    • Once the tab is open, the strip on the keyboard can be removed.
  3. Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 6 mm PH1 Philips head screws under the keyboard.
    • Carefully pop off the cover using the plastic opening tools and your hands.
  4. Dell Inspiron 17-3721 Optical Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 17-3721 Optical Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 17-3721 Optical Drive Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 4 mm PH1 Philips head screw holding down the optical drive.
    • Use your hand to slide the drive out of the device.
Kevin Prairie
crwdns2935283:003/20/18crwdne2935283:0
466 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S5-G3, Peak Spring 2018 crwdns2935289:0UMass Dartmouth, Team S5-G3, Peak Spring 2018crwdne2935289:0
UMASSD-PEAK-S18S5G3
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 414
