Dell Inspiron 16-7610 Motherboard Replacement
  1. Dell Inspiron 16-7610 Motherboard Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 16-7610 Motherboard Replacement, Back Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device over, so the backside is facing up.
    • Use a Phillips #00 screwdriver to remove four 4.00 mm screws.
    • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
    • The last two screws should remain in the back case and can't be removed.
    • Three of the screws are dummy screws, only screwed into retainers. They are not holding anything in and can be left in place for simplicity.
  2. Dell Inspiron 16-7610 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
    • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
    • Remove the back case from the device.
  3. Dell Inspiron 16-7610 Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 16-7610 Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 16-7610 Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 to remove the five screws securing the battery to the laptop.
    • Pull the bundled cable away from the connector in the same direction as the wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Use both hands to life the battery up and remove it from the laptop.
  4. Dell Inspiron 16-7610 Motherboard Replacement, Wi-Fi Card: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 16-7610 Motherboard Replacement, Wi-Fi Card: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the screw that secures the Wi-Fi card bracket to the system board.
    • Lift the Wi-Fi card bracket off of the Wi-Fi card.
  5. Dell Inspiron 16-7610 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 16-7610 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to disconnect the coaxial cables from the Wi-Fi card.
    • Slide the Wi-Fi card from the slot to remove it from the device.
  6. Dell Inspiron 16-7610 Motherboard Replacement, RAM: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 16-7610 Motherboard Replacement, RAM: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 16-7610 Motherboard Replacement, RAM: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the plastic cover over to reveal the RAM stick. Do not pull the plastic cover off.
    • Pull the two RAM retaining arms away from the center of the RAM stick.
    • The RAM stick should "pop" up slightly from its socket.
    • Pull the RAM stick out of the socket. Repeat for each of the RAM sticks you are replacing.
    • Align your new RAM sticks on to the sockets when installing them to prevent any damage to the pins below.
  7. Dell Inspiron 16-7610 Motherboard Replacement, Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Double check that every component is removed from the motherboard.
    • Disconnect all the pin and ribbon cables from the motherboard.
    • Locate and remove all the screws that are holding the motherboard in place.
  8. Dell Inspiron 16-7610 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 16-7610 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 16-7610 Motherboard Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screws and cables connecting the fans to the motherboard.
    • Lift the fans off of the board to remove.
  9. Dell Inspiron 16-7610 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 16-7610 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #00 screwdriver to loosen the four screws from the heat sink.
    • Use both hands to gently lift the heatsink up.
    • Be mindful of the thermal paste on both the motherboard and the heatsink.
    • We recommend reapplying thermal paste on the heatsink before installing the new motherboard.
  10. Dell Inspiron 16-7610 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 16-7610 Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up on each side of the press-fit connector, then lift the connector straight up to disconnect it from the motherboard.
  11. Dell Inspiron 16-7610 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard out of the device.
Jerson Gomez
crwdns2935283:002/02/23crwdne2935283:0
892 crwdns2915208:0crwdne2915208:0
Gateway, Team 1-3, Pee Spring 2023 crwdns2935289:0Gateway, Team 1-3, Pee Spring 2023crwdne2935289:0
GCC-PEE-S23S1G3
"Three of the screws are dummy screws, only screwed into retainers. They are not holding anything in and can be left in place for simplicity." not true for me (my version have graphic card) and this screws have to be removed to open your labtop. also ssd m.2 space dont look like pictures displayed.
To replace keyboard you have to remove like at least 20 plastic rivet. you can still mount a new keyboard whitouth a new palmrest and keep broken rivet and the result is still good.
Roméo.Str - crwdns2934203:0crwdne2934203:0
also you dont have to unmount heatsink to remove motherboard. only fan need te be unmouted. one my version (with nvidia) you cant remove heatsink without motherboard.
if you remove heat sink, replace thermal paste. but if you dont touch swrew with spring you dont have to
crwdns2936753:030crwdne2936753:0 56
crwdns2942667:0crwdne2942667:0 1,374
