If your Dell Inspiron 16-7610 begins to have random freezing, blue screens, restarting, or beeping noise your motherboard may be wearing out and need replaced. Motherboards tend to wear out over time or can be damaged from water, power surges, and other foreign objects getting inside your laptop.
Before beginning your motherboard replacement, be sure to properly diagnose that the motherboard is faulty. This can be done by taking it to a local computer shop or if your laptop shows the above issues.
After properly diagnosing the motherboard is faulty you may begin the repair, be sure to purchase the proper motherboard. Motherboards that will work for the Dell Inspiron 16-7610 include the 0FHWFDFHWFD CN-0FHWHFD motherboard. You may also do your own research to find different motherboards that will work.
Warning: Be sure to power off the laptop and disconnect it from the AC adaptor before repairs begin
Flip the device over, so the backside is facing up.
Use a Phillips #00 screwdriver to remove four 4.00 mm screws.
Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
Three of the screws are dummy screws, only screwed into retainers. They are not holding anything in and can be left in place for simplicity.
-Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
Remove the back case from the device.
Use a Phillips #00 to remove the five screws securing the battery to the laptop.
Use the wide end of a spudger to push on the connector tab to slide it out of its socket.
Use both hands to remove the battery from the laptop.
Use a Phillips #00 screwdriver to remove the screw that secures the Wi-Fi card bracket to the system board.
Lift the Wi-Fi card bracket off of the Wi-Fi card.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to disconnect the coaxial cables from the Wi-Fi card.
Slide the Wi-Fi card from the slot to remove it from the device.
Flip the plastic cover over to reveal the RAM stick. Do not pull the plastic cover off.
Pull the two RAM retaining arms away from the center of the RAM stick.
Pull the RAM stick out of the socket. Repeat for each of the RAM sticks you are replacing.
Double check that every component is removed from the motherboard.
Disconnect all the pin and ribbon cables from the motherboard.
Locate and remove all the screws that are holding the motherboard in place.
Remove the screws and cables connecting the fans to the motherboard.
Lift the fans off of the board to remove.
Use the Phillips #00 screwdriver to loosen the four screws from the heat sink.
Use both hands to gently lift the heatsink up.
Use a spudger to pry up on each side of the press-fit connector, then lift the connector straight up to disconnect it from the motherboard.
Lift the motherboard out of the device.
"Three of the screws are dummy screws, only screwed into retainers. They are not holding anything in and can be left in place for simplicity." not true for me (my version have graphic card) and this screws have to be removed to open your labtop. also ssd m.2 space dont look like pictures displayed.
To replace keyboard you have to remove like at least 20 plastic rivet. you can still mount a new keyboard whitouth a new palmrest and keep broken rivet and the result is still good.
also you dont have to unmount heatsink to remove motherboard. only fan need te be unmouted. one my version (with nvidia) you cant remove heatsink without motherboard.
if you remove heat sink, replace thermal paste. but if you dont touch swrew with spring you dont have to
