Dell Inspiron 1564 Display Assembly Replacement
  1. Dell Inspiron 1564 Display Assembly Replacement, Note the Routing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface.
    • Note of the routing of the Mini-Card antenna cables and remove them from the routing guides on the bottom of the computer.
  2. Dell Inspiron 1564 Display Assembly Replacement, Remove the Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws on the bottom of the computer that secure the display assembly to the computer base.
  3. Dell Inspiron 1564 Display Assembly Replacement, Pull the Cables: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the Mini-Card antenna cables up through the slot in the computer base.
  4. Dell Inspiron 1564 Display Assembly Replacement, Note the Routing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Note the routing of the Mini-Card antenna cables and remove them from the routing guides on the palm rest.
  5. Dell Inspiron 1564 Display Assembly Replacement, Disconnecting the Display Cable: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the display cable from the connector on the system board, and remove the display cable grounding screw.
  6. Dell Inspiron 1564 Display Assembly Replacement, Removing the Screws: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the display assembly in place and remove the three screws that secure the display assembly to the computer base.
  7. Dell Inspiron 1564 Display Assembly Replacement, Lifting the Display Assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the display assembly off the alignment posts on the computer base.
  8. Dell Inspiron 1564 Display Assembly Replacement, Placing the Display Assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the alignment posts to place the display assembly on the computer base.
  9. Dell Inspiron 1564 Display Assembly Replacement, Replace the Screws: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the three screws that secure the display assembly to the computer base
  10. Dell Inspiron 1564 Display Assembly Replacement, Connecting the Display Cable: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Connect the display cable to the connector on the system board, and replace the display cable grounding screw.
  11. Dell Inspiron 1564 Display Assembly Replacement, Routing the Antenna Cables: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Route the Mini-Card antenna cables through the routing guides on the palm rest.
  12. Dell Inspiron 1564 Display Assembly Replacement, Thread the Cables: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Thread the Mini-Card antenna cables through the slot in the computer base.
  13. Dell Inspiron 1564 Display Assembly Replacement, Replace the Screws: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the computer over and replace the two screws that secure the display assembly to the computer base.
Terrence15
crwdns2935283:012/18/17crwdne2935283:0
79,831 crwdns2915208:0crwdne2915208:0
crwdns2935297:0441crwdne2935297:0
RampUP America, Inc. crwdns2935289:0RampUP America, Inc.crwdne2935289:0
Community
crwdns2931471:043crwdne2931471:0
crwdns2935297:01,991crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,194
